Oil Consumption on 4.3L
WildWoolyB
Hi boat experts. I have 98 Chaparral with 4.3L mercruiser. I bought it this spring. Had an oil change done when winterized. I've had the boat out 20-25 times already this spring. I noticed my oil is down almost a quart. Should this motor use oil? Is this normal oil use? thanks. from what I've been told the boat did not have many hours on it and the engine and boat looked immaculate.
danond
Re: Oil Consumption on 4.3L
How much time did you spend with the throttle wide open?
Check compression, that'll give you some information as to what kind of shape your cylinders/pistons/rings are in.
WildWoolyB
I was running it alot at wot @4800 rpm's. Would that explain the oil consumption or should this motor not burn any oil? thanks.
danond
"Alot" at WOT isn't a great idea. Not that it won't take it, but 4800 rpm for extended periods of time is still up there for a run-of-the-mill v6.
That's probably why you're short on oil. I'd do a compression test anyway, though.
180shabah
Do the comp test, and back off the throttle a little and see if you consumption is eliminated.
My '96 uses ZERO oil, but it doesn't get hammered on for extended periods either.
Nope,.... My motor has over 1000hrs on it,+ uses No oil between changes...
JustJason
eagh.... I'm from the school that says all boat engines drink a little oil because of the load they are under.
That being said....
The newer the engine the less oil it will drink
The better quality oil you use, and weight, the less it will drink
The older the engine, the more it will drink
The higher the rpm you run, the more it will drink
If you run low quality oil, or low viscosity, it will drink oil.
Do an oil change and run the Merc oil (25W-40) and see if your still drinking oil.
180shabah
That's alot of drinking
