Oil Cooler Change?
wazzu98
Went out today and sprung a leak in my oil cooler. It is a Merc 4.3Litre V6. Question is, do I have to drain the oil, before changing?
denniz
Re: Oil Cooler Change?
4.3 doesnt have a oil cooler, it has a power steering cooler. and no you dont have to drain anything. pull it off and repair it(brazing) or replace it. D
wazzu98
Yes Rod, you are correct it is the power steering oil cooler that is damaged. Is there a way to test it if I braze it other than reinstalling and putting the boat in the water.<br /><br />Any other thoughts?
denniz
guess you could pressure test it but it would faster to put it back on and try it.D PS RUN it on a hose
wazzu98
I successfully removed my power steering oil cooler this morning. Any one know a good place to purchase a new one.<br /><br />Note To Self -- Drain cooler when winterizing boat this winter!
wazzu,<br /> Go to ebay,+ search merc... Those coolers are a dime a dozen.... And Quite Cheap, Sometimes....<br /><br />Last time I had mine out, I tapped a drain plug into the in-coming nipple....
