We have an oil cooler already connected to the output on the raw water pump on our 350 merc. I believe it must have been a transmission oil cooler due to the fact that red oil leaked out of it when I took the plugs out. I was wondering if I was to clean it out, that it would be suitable to use as an engine oil cooler. The only issue I could see, I do not surly know though; is pressure. From what I have read online it would seem that engine oil and tranny oil are usually close to the same operating pressures though, so again, would it be fine to use? Is there even much of an advantage to using an engine oil cooler? As well, would it be best to just hook it up in between the engine and oil filter?
Thanks!
Thanks!
