doctorchuck
- Joined
- Mar 13, 2021
- 4
Noticed oil in water outside my 175HP Mariner. Pulled the cover and quite a bit of oil pooled in the housing. Started the engine and noted a frequent drip of oil from the vent tube. Took off the in line check valve, put some carb cleaner thru it , dried it out, put it back together and still leaking from the vent tube when the engine is running. Engine runs fine. Thoughts? Do I just need to replace the check valve, I believe it is a 2 or 4 PSI valve. Anything other than a faulty check valve cause this to happen?
