oil drips at steering column
Edge180
I've got a slow oil drip under the dash behind my steering column. Is this a simply fix by tightening screws down or is it indicative of other issues elsewhere?
Re: oil drips at steering column
Is your oil pressure gauge electrical or does it have a small hollow tube running back to a fitting on the block? If it has the tube, check for a leak.
Edge180
I will check and post back when I get home... thanks!
jbetzelb
If it isn't your oil pressure guage make sure it isn't lake water coming from your speedometer.
