Oil Filter Mercruiser 7.4L OF126634
Juttmk
Looking for a WIX Racing part number for this application. The engine builder outfitted the boat with a hi-flo pump and recommended using a Wix Racing filter.. Unfortunately during the filter removal process the part number on the sticker was damaged. Does the filter require a anti drain feature, since the filter is mounted vertically?
Bt Doctur
Brand: Wix Filters
Manufacturer's Part Number: 51060R
Part Type: Oil Filters
Product Line: WIX Filters Racing Oil Filters
Summit Racing Part Number: WIX-51060R
UPC: 00765809129269
Oil Filter Style: Canister
Height (in): 5.170 in.
Outside Diameter (in): 3.600 in.
Filter Bypass Relief Valve: No
Anti-Drainback Valve: Yes
Smallest Particle Filtered: 61 microns
Thread Size: 13/16-16 in.
Gasket Outside Diameter (in): 3.444 in.
Gasket Inside Diameter (in): 3.100 in.
Gasket Thickness (in): 0.260 in.
Quantity: Sold individually.
Juttmk
Is the anti drain back actually going to serve any purpose on an inverted bottom mount filter setup? I went ahead and purchased it anyways, but was just curious as to why this would be recommended.
