Oil filter seal leaking, 5.0L
Bumperlt12
I am affraid to tighten it down anymore then i have.
Is this a common issue? It's leaking oil into my bilge.
Do I need to add more of a seal somehow?
Re: Oil filter seal leaking, 5.0L
Ayuh,.... Take it Off, 'n look to check the old o-ring got removed, before the new 1 was replaced,...
Bumperlt12
Damn that means I have to drain all the oil again. Thank you sir.
Nope,... No reason to drain the oil,... the sump won't drain through the fliter housin',...
spdracr39
And make sure to lubricate the seal with a little oil before installing to help keep it from pinching.
You will get a small amount of oil when you remove it, small.......
It should be leak free with a good hand tighten.
What filter is it?
Bumperlt12
Sierra brand. Haven't had time to mess with it but soon.
