Re: Oil Filters
Sorry about that!
Motor is a 9.9 Mercury (Tracker) 4 stroke serial number 0G821379
I purchase an Oil Filter from a Mercury dealer earlier this summer. The dealer said there was a serial number break for the correct part but gave me the one he felt worked for my motor. The Fram application chart say's I should use Mercury Filter number 35-822626Q03 the one I purchased is a 35-822626K03. That online look up shows no serial number break one filter for all. Do you suppose this is a part number change only and basically the same filter or do you suppose I got the wrong part? The dealer is over an hour away. If I don't get a answer I'll call but I thought maybe someone might know. Anyone know a online Mercury lookup for oil filters.
The serial number break looked like this at one time, Part number 822626Q1 FILTER, Oil SN# USA-0T800999/BEL-0P267999 & Below.
Part number 822626Q03 FILTER ASSEMBLY, Oil SN# USA-0T801000/BEL-0P268000 & Up.
But over time, part number 822626Q1 has Superseded to part number 822626Q03, And when I look up part number 822626Q03 in the mercury parts crossover reference sheet it shows part number 822626K03 to be a match, So your good to go with your "K" number.
The only differents between the two part numbers should be the color of the oil filter, "Q" = white, "K" = black.
Here's a link to your engine parts for you.
http://www.mercruiserparts.com/selectDocs.asp?doc_nbr=803183
