Oil From Grease Filled Hub??
DaveJ50
One side of my trailer has a small amount of oil in the Bearing Buddy cover each time I remove it. The other side is always completely dry. The hub has never run hot and is due for re-packing anyway but I was wondering what causes the grease to produce oil and if I need to do anything different.
bgbass.1
Re: Oil From Grease Filled Hub??
getting some water mixed with grease
Mike722
Might be the wrong type of grease, sunlight, or air temp? Water should make gray or milky grease/oil.
DaveJ50
This is clear/amber and looks to be 100% oil. The same thing you might find running down the side of a grease gun.
This side has never run hot, the other side runs warmer. I was going to repack this side anyway since I did the other side in the spring. No grease/oil on the inside or outside of the tire, just some oozing out the face of the bearing buddy.
I'll repack it this weekend and post what I find inside.
Thanks
wire2
Some dino based greases will weep oil/separate if not mixed regularly by the bearing motion. Your bearing buddy on the dry side has a better seal.
1730V
Oil is the light end of grease. One hub is getting warmer than the other, with no water present, I'm assuming.
