oil/fuel mix on '57 Johnson 35 HP?
sfure
From the forum postings I've read, I'm not sure whether to use 24:1, 32:1 or 50:1. Any help would be appreciated. :confused:
rickdb1boat
Re: oil/fuel mix on '57 Johnson 35 HP?
24:1 is what's recommended for your motor.
sfure
Does it matter that today's oils are probably better than what was available in '57?
rolmops
In 1957 they meant for you to use a non detergent 30 weight engine oil. Now you use a much better oil: TWC-3. I run my '57 on 1:32 because of it,but I certainly would not try anything leaner than that.
rickdb1boat
sfure <br /><br />24:1 is 24:1, no matter what oil you use. Just use TCW-3 oil mixed at 24:1 for proper lubrication. The richer mix is to seal up the tolerances in older motors.
sfure
Thank you for the information fellas. :)
