oil gas mix
caspari
Have twin 135 mercs is it possible to bypass the oil enjection system and run a 50 to 1 oil gas mix? If so how and what do I get rid?
LubeDude
Re: oil gas mix
What year are these engines, I wouldnt do it unless they are of the old style with the plastic gear on the crankshaft. You will be less than happy with the low speed performance.
rickdb1boat
Re: oil gas mix
They are 91's Lubedude. I would leave it alone, as they are very reliable. If you do have the plastic gear, replace it with the newer style gear and you will be good to go. That was the ONLY problem with them..
LubeDude
Re: oil gas mix
The gear is on the crank and the engine has to be torn apart so I understand, but the 91 should be fine!
caspari
Re: oil gas mix
let me make sure I understand this correctly....I have to take the motor apart and replace a gear with the newer type...?... better to do this than run mix in tank..?
ZmOz
Re: oil gas mix
Having a reliable oil injection system is ALLWAYS better than mixing. Don't ask how I know... :D :rolleyes:
caspari
Re: oil gas mix
Do I have to take the motor apart to change the gear in the 91 135?
LubeDude
Re: oil gas mix
No, we are not telling you to take the engine apart and change the gear, we are telling you to leave it alone. I only said that because you cant change the gear with out doing this, but you do not need to! When the older ones failed, that was the weak link.
caspari
Re: oil gas mix
What could be the problem then... any suggestions? getting a continuous rapid beep. beep. beep...
caspari
Re: oil gas mix
seems the oil tank cap was loose. the beeping has stopped for now.
