I have a 60hp that has been bored 3 over runs great. But I have to keep pumping the oil bubble to keep oil alarm from going off what do I check to fix or how can I by pass and per mix
Sounds like an air leak between the primer and the oil injection pump. Of course it could be a bad oil injection pump. Replace the oil line and see if it gets better. Premixing fuel is a good idea until you figure out the issue.
