Re: oil in exhaust manifold 1989 3.0L mercruiser
Just to be certain, as I am sooooooooooo inexperienced at this, you are referring to the gasket/surface found when the manifold is removed?
The exhaust manifold cylinder head gasket.
Should I replace the gaskets on the front and back of manifold while I have it dismantled? Would I be better served to wait until spring to perform this repair so the new parts don't have to "survive" the winter?
Nope,.... The manifold bolts to the head,...
The Riser bolts to the Manifold, 'n directs the exhaust, 'n spent water overboard....
Pull the Riser, Off the Manifold,... Those gasket surfaces....
Just Drain the block, 'n manifold before ya start takin' things apart...
As for the forward, 'n aft manifold plates,...
If they ain't leakin', leave 'em alone...
Do it
Now, 'n Santa will know what to bring ya,....
