HalfFish5087
- Joined
- May 30, 2012
- 278
2 or 3 weeks ago I changed the oil in the outdrive. Well the manual said it would take 2.5 quarts and I thought to myself that this sounded like way to much, but didnt think anything of it at the time. Well while I was adding oil, I was just pumping away while watching the oil go down in the bottle, to suddenly look up and see oil all just pouring all over the place as I had overfilled it. Does anyone ever get the design capacity of nearly 2.5 qrts in their outdrive?
I am currently rebuilding the transom and noticed gear oil in my bellow and I'm assuming that I have a bad input shaft seal which allowed the oil to enter the bellow.
I'm assuming I need to replace seal no. 82, along with any other seals required from tear down. However, to do it appears that I just need to remove the 4 bolts on the cover place and the shaft will release from the outdrive. Can someone confirm. Additionally, will I mess up any mesh or is there any pre-load that will compromised?
Thanks!
VP DP-S1
Thanks!
VP DP-S1
