Re: Oil indicator flashing on digital yamaha gauge
the 10 micron filter update I was refering to is the inline filter between the engine ful pump and the VST tank.
as far as making oil its not a problem if the boat is propped CORRECTLY and the thermostat is checked/inspected per the maint schedule.
even a lightly overpropped EFI outboad will make oil even if everything else is correct.
running cold is another big making oil problem as the ECU will keep the injector pulse width to rich,ECU's are rather stupid as they can only react to inputs.
check your engines tech bullitens, the early runs of the F115 had some updates to both the t-stat,oil dipstick and some ECU's.
as to oil reccomendations any FCW rated oil in either 10w-30 or 40,depending on ambient air temps, will be sufficient and can be found in your operators manual.
most synthetics are NOT FCW rated and not reccomended.
the option to buy or not to buy filters is yours, but I will tell you if the VST doesnt get a CLEAN supply of fuel it will clog the high pressure pump filter and the injector screens.
choice is yours,pay now,pay later
thats the beauty about my job,sooner or later I get to see it
