Oil Injection Question
redfish10
I have a 1995 Mercury Tracker 40hp 4 cylinder. The oil injector/pump is not functioning. Is it possible to remove the oil injection system and run pre-mix instead of the oil injection without hurting the motor. If pre-mix is a option what would be the best mix ratio to run. Thanks
redfish10
Re: Oil Injection Question
Forgot to ask. If removing oil injection is possible, what is the best way to go about doing it correctly.
j_martin
It shouldn't be a big deal. On a V6, when you remove the oil pump, you have to put in a block off plug, which has an appendage on it specifically to keep the end bushing in the block so it doesn't come loose and fall into the crankcase. Judging from the parts picture, yours doesn't have that bushing.
With that caveat, take off the pump, tank, and oil alert electrics (module) and fashion a gasketed cap to cover the oil pump hole in the crancase.
Mix yer oil in the gas at 50:1, and yer good to go. No, Amzoil at 100:1 will not work. (for long)
If you do a lot of idling, you might want to go to a synthetic, like Pennzoil.
If your main mode of operation is slow speed trolling, you might want to fix the oil pump so you aren't changing plugs all the time.
hope it helps
John
MercGuy
Just curious, how did you determine that the injection wasn't working before your engine seized ??
