Re: Oil injection removal
I have a 40 hp 2cycle 1986 unit, the oil pump is stuck in full open and the throttle linkage is attached to the oil pump. When I attempt to start the engine is in full throttle. So I shut down right away. I was thinking of removing the oil pump and pre mix the fuel. or should I disassymble the old linkage and leave the oil pump on.<br /><br />Brent
