Oil Injection removal
gbrowne63
i just removed the oil injection on a 1988 135HP. My question is what do i do to the carbs with a now richer mixture. I had a 1986 and it had idle air jets i made bigger so it pulled hard right off idle.
Chris1956
Why exactly is the mixture richer? You went from a 50::1 oil injection-created mix to a 50::1 premixed fuel.
Chris1956
OK, Even if that is true, of which I am unsure, how long does it take when you first go to idle, before the mixture becomes 100::1? How long dies it take before the mixture becomes 50::1 as you throttle up slowly?
Your engine doesn't care a lot what the mixture is. You obviously need a 50::1 mix for high speed operation, but they run just fine on a 50::1 mix at idle as well.
gbrowne63
when I had my 1989 merc 115 2+2 and disconnected the oil injection I had to adjust the mixture screws so it would accelerate well, same thing on my 1986 135HP but I drilled out the idle air jets. I don,t see them on this carb arrangment.
gbrowne63
the oil pump is dirrectly connected to the thottle linkage so from 100:1 to 50:1 is a progressive thing.
Texasmark
I pulled the drive gear out of my oil pump on a 2002 90 hp Merc. Went to 50:1 pre mix. Only thing I saw/felt/had different was a light puff of smoke when doing the (start of the) hole shot coming out of the no wake zone that I didn't have before with the 90:1 my service manual said my engine ran at idle using the onboard, internal oil pump.
Chris1956
Gee, I don't think you should make any mods to the carb jets. If it runs poorly, clean the carbs and adjust the idle mixture, as you would on any motor.
I would guess that thousands of Mercs have been converted to premix. I understand that there are cover plates sold, to fill the hole where the oil pump sits. That means a common conversion, at least to me.
gbrowne63
I just watched a utube video on carb rebuilds and answered my own question,thanks for all the input. GORD
Chris1956
Some of the V6 engines had fixed low speed jets. That makes your question academic.
