I just purchased a boat with a 1997 50hp johnson motor. I was told that it is better to run the engine pre mixed as opposed to the oil injection that it has now. I heard that the oil pump can stop an cause a major engine problem. Is this common? Do you know if this engine has a warning system just in case the oil stops flowing? If not, can i have one installed? I dont know much about boat engines.
