oil leak, 1986 50 horse 4 cylinder...
I've got unburned 2 stroke oil leaking out from under the flywheel. I thought it was the crank seal, I replaced that and I'm still getting a leak. What else should I check? As far as I can tell, all nuts and bolts are tight... Also, I'm getting a periodic surge at full throttle. I'm wondering if it's related to crankcase vacuum...
etech2008
Re: oil leak, 1986 50 horse 4 cylinder...
hello.
inspect the stator and trigger some of those older models when the stator and or trigger start to go out the use black crap that looks and even smells lke two stroke oil.
good luck let us know!!!!!!!!
Dave1027
Could there be a bleed return hose that's leaking?
chum1
I think there is a small hose that pumps up a fuel oil mix and lubes the upper bearing, make sure its attached to that small nipple under the flywheel and also not chafed.
I replaced mine with new yellow poly vinyl looking stuff used for weed whacker fuel lines that I got at the local auto store. No more leaks.
hello.
Stator and trigger are both new and not leaking. It's definitely 2 stroke oil. I'll check the oil feed hose when I get a chance. Thanks for the tips!
