cobraowner
- Joined
- Jun 21, 2008
- 23
Noticed oil in the bilge after a day out and find it is dripping from the front crank seal on my 93 Ford 5.0 HO. Not sure if oil pan needs to be dropped or not. Can the seal be replaced without removing the timing chain cover? It looks like removing the timing chain cover would require the oil pan to be removed. The manual indicates engine removal to pull the pan, not sure why. Looks like I can access all fo the pan bolts.
