Oil leak from lower cowling
pigfish
I have a small amount of oil leaking down the shaft after running my 2003 225hp evinrude ficht for a while. Doesn't seem to amount to much but is annoying & messy. the twin motor does not do this. anyone have this problem or any suggestions?:confused:
tashasdaddy
Re: Oil leak from lower cowling
recirculating hose is loose or leaking.
exsailer
I have similar issue but hose (I assume recirculation) appears to be attached to a blind hole.
Faztbullet
Check your oil lines and oil pump for leaks and inspect throttle body shafts. If oil running down shafts it the oil mist condensed in intake. There was a kit for the shafts at one tme if I remember correctly....
