Is there some water with it? Probably just a mid section drain hole and since exhaust gasses contain oil and exhaust is via the mid section, expect to see some of that. Unless it's a 4 stroke you have 2 sources of oil...one is with the fuel, before and after combustion, and the second is the lower unit gear oil, in the prop area.
