Re: Oil leak from top of motor
The color of it appears like a fuel mix leak to me.It may just be two cycle oil residual dripping from the bottom of intake silencer and running down.However I recommend inspect all fuel line connections from the engine fitting to the fuel pump and up to each carburetor inlet.Also inspect the carbs themselves for any eveidence of leaky gaskets.You can try and pump up the fuel primer bulb until completely firm or until the line pressure exposes the leak.Not knowing the type of grease or lubricant you use or not ,it also looks to be in the same area as the upper bushing of the engine swivel bracket.The proper grease is not noted for running out like the pics show ,but then without further info on the type of grease/lubricant used to grease bushings,,I can't be sure.<br /><br />Is there any odor of gasoline in this dribble?
