I have a 1987 Mercruiser MCM140 181 CID with mercarb.
The engine has been through a complete overhaul, including new lifter, new piston on one cylinder, new powerhead, all gaskets are new, new manifold and
rebuild of carburator. The engine runs well with WOT RPM at 4400 and idle RMP
(in gear) at 700. Spark plugs has been checked and there are no signs
of fouling of the plugs. On WOT the oil pressure gauge is 60 psi.
The oil on idle the oil pressure gauge is fluctuating from 20 - 40 psi, and
the oil consumption has been excessive with oil floating around in the bilge.
There are oil dripping from the vent house from top cover and flame arrestor, and there are oil floating around the vent cover , manifold top and carburator gasket.
It seems to me that the main cause is to much oil been vented out from the crankcase and into the flamearrestor.
Any comments?
Any comments?
