Oil Leak Volvo/Chevvy 350
aznewsh
I have a 1977 Sea Ray 24' Cuddy Cabin with a Volvo/Chevvy 350.<br /><br />This weekend when I checked the oil before leaving the marina I noticed it was very low and took 2 quarts to bring it to an acceptable level.<br />I put about only about 2 to 3 hours use on the engine and noticed the bilge contained a lot of oil, after checking the dipstick and topping off again I found it had lost about 3 quarts almost certainly to the bilge.<br /><br />I inpected all around the engine that I could see and was not able to see oil on the engine anywhere on top, front or sides or back where I could see with the possible exception of a little around the oil pressure sending pipe at the back of the engine, I also looked in this area with the engine on idle but wasn't able to see the oil escaping obviously.<br /><br />The temperature and the oil pressure on the boat are both good.<br /><br />Can anybody suggest where else I might look for a leak that could loose that ammount of oil in such a short time or ask me question if you need more info.<br /><br />Thanks...
ahein
Re: Oil Leak Volvo/Chevvy 350
It could be the rear main seal. Use a mirror and flashlight to check for a leak between the rear of the oil pan and the bellhousing. Unfortunately, you will have to pull the engine to fix it. :mad: Or it could also be something as simple as a loose oil pan drain plug or loose oil pan bolts. To lose that much oil in that short of a period, without the boat smoking like a house on fire, certainly points towards a leak.
aznewsh
The rear main seal did occur to me, however I had ruled that out thinking it was leaking much faster than I would expect a rear main seal to leak, any opinions on that?
Blk-n-Blu
az, have you checked the oil filter? should be port side of motor aft near the oil pan. You could remove and replace it easily. I believe a Fram PH-30 will replace it but be sure to check that number.Pick up a filter at Wal-Mart and do a Quick swap to eliminate that as a possible leak.
aznewsh
Actually now that you mentioned it, I did replace the oil filter this year whilst doing the oil change, the oil filter I took off was installed by the previous owner and was on so tight that it was nearly impossible to remove, I even broke an oil filter wrench in the process, I wonder if that is why it was so tight, maybe there is a problem getting that to seal??
Blk-n-Blu
az, The oil filter should only be hand tight and the mating surface "clean" and fresh oil on filter gasket. The reason I use the fram filters is they have a good gripping finish which makes for an easy change and they also have the "extra guard" and "extra capacity" filters.<br />I don't work for Fram and boat mainly on fresh water lakes.
Fishermark
I suppose it isn't a big problem in Arizona, but here in Florida my first thought on an old boat like that would be a rust problem. Especially since it is apparently a sudden leak. I have had oil pans rust through - or the dip stick tube, etc. Just something to check.
