cpubud
- Joined
- Jun 18, 2008
- 468
I have a 2000 merc 5.0 there is a oil leak at the oil drain quick connect where the rubber drain hose is attached .I drained the oil ,cleaned the fitting ,replaced the o-ring and it still leaks. the fitting does not appear to be threaded in (no place to put a wrench on it ). before i go and try to manhandle it out and break it off can anybody tell me if it does unscrew from the oil pan.... thank you
