I've got a 4.3L Mercruiser with an oil leak. It's coming from the timing cover area. I just pulled the engine, dropped the pan and installed a new oil pan gasket and timing cover. I torqued everything down good and added some gasket sealant to the corners before doing so.
Finally get everything back together and it still leaks! Hard to see up there what it could be exactly. Leak is definitely a lot less than it was before, looks to come straight down. I took the harmonic balancer puller back to AutoZone so I haven't pulled it again to see if maybe the leak is coming from somewhere else.
Is it possible something else is leaking in that area? I felt like I did a pretty good job. Can't believe I might have to take it to a shop after all that.
