Oil Leak
Art Reed
Slow leak while parked, from lower unit drain plug. Is there a o-ring for plug available?
1997 50 hp merc, 2 cycle.
mike_i
Ensign
Yes there should be a washer or O ring on the plug and the plug should be magnetic. When you get the washer or O ring and remove the plug you may as well change the lube, if the oil got out water may have gotten in.
