Oil Leak????
Solittle
Re: Oil Leak????
Welcome Tom - This could be either unburned oil from combustion or gear oil. You need to check the gear oil. If it is relatively clear and the gearcase is full you should be OK. Make sure you use new o rings on the vent & drain screw. If water comes out of the gearcase or the oil is milky in color then you have a leak in the gearcase. At that point you will need to roll up your sleves and fix it (get a shop manual at this point).
TKE381
Re: Oil Leak????
Originally posted by Tom McC:<br /> I just acquired a 1958 Evinrude 35hp. I put it in the water and little oil bubbles came up after it started. I pulled it out and ran it with the hose attached. A thin brown oil appeared just above the water intake dripping out. Is this lower unit gear oil? If so, where should I start to look for problems. I am new to older outboard repair. Just looking for a place to start.
