Oil leaking from valve cover breather...
SynPDX
Curious if anyone here knows where I can start in the troubleshooting process.
I have oil leaking from the breather elbow. It's not much, but enough to cause concern.
This is not a PCV valve....
Thanks ahead of time!
saltydogjeff
Re: Oil leaking from valve cover breather...
Did you check your oil levels and if there was any signs of water/coolant in your oil? Such as frothy white/milky white.
Edit: Also, what type of engine, year, s/n.
SynPDX
Yeah, engine oil looks good. It's level is perfect, and oil looks healthy.
Engine is a 1998 Mercruiser 3.0 Serial 0L066610
makonnen
Check for excessive blow by... ie: combustion pressure leaking past the rings into the cylinder block and coming out of the valve cover / breather elbow.
Always start your diagnosis with the easy stuff:
Open the oil filler on the valve cover, start the engine, hold a tissue paper over the oil filler, check for blow by at various RPM's.
When you're ready, you can go deeper with a cylinder balance test (also easy), compression and leakdown test. I wouldn't trust the result of any one of those tests ... have to analyze the results of all three tests.
