1972 Johnson 25hp. Changed the water pump and impeller, rebuilt the carb, put in new wires and plugs and ran it in a trash can for several minutes. Ran fine for a motor that sat without running for 10+ years. Put it back in the garage and noticed the other day oil leaking onto floor. I smelled it and it doesn't necessarily smell like gas, just oil. Anyone have an ideas where it is coming from or what is causing the leak based on where the oil is dripping in the picture? If you can't tell from the picture, it is coming from that hole above the prop.
