I have a 1982 Johnson Seahorse 35 hp longshaft, pull start.Just brought it out for the season,started up,ran well. I took it for a little run around the cove,no issues, everything running well, at the dock I notice it is leaking oil around the area where the lower unit bolts on to the rest of the engine.Not a lot, just enough to make a mess. I didn't notice it before...ps..I changed the lower gear oil fluid the other day.(second time I did this,done right as far as I can tell).<br />Is this a normal thing? Is that area sealed?
