oil leaking
Bassy Jr.
My 93 Force is leaking oil from the lower unit out of what looks like a couple little holes up above the plug, just under a fin ( I don't know what it is called) that goes around it, I just see some on the driveway when it is parked, what might this be,is it normal??
roscoe
Re: oil leaking
normal, unburned oil and fuel from the exhaust.
jerryjerry05
Re: oil leaking
If it's something new happening you should drain the oil and see if there is water in the oil. It won't hurt to change the oil again.If you have never changed the oil yourself have someone do it for you.
If it has water ,then pressure test to find location.You might have to drop the lower unit to check.Jerry
