oil leaking
atwitsend
I have oil leaking from,the area of the crankcase ventalation filter area.
it is a 6 Cyl Volvo deisel AQAD41A
what would cause oil to come out of the crankcase ventilation canister ? i am at a loss please help.
Engine
AQAD41A
Production period
1986-1989
Operation
4-stroke
Cylinder configuration
6
Bore (mm)
92
Stroke (mm)
90
Compression ratio
16:1
Displacement (litres)
3.59
Power (hp)
200
Max engine speed (rpM3800
Vosman
Re: oil leaking
Replace the filter first, then retest. Next to filter is a small shaped can. That is the blow off valve. If filter is restricted the valve will lift and crankcase fumes will exit. No filter to separate oil and oil film well be left all over the place.
atwitsend
Re: oil leaking
thanky you Sir ,that seemed to have solved my oil issue. thanks again!!!
atwitsend
Re: oil leaking
i recently have taken the boat out for a ride after changing the air breather element. I have again lost about a half a quart of oil into the bilge. now that the filter has been changed where should i look to solve this issue / please help with any suggestions.
Vosman
Re: oil leaking
Inspect the engine with a bright torch and mirror. See if you can see traces of where oil is coming from. There are many spots that it could be. We need to narrow it down.
Grub54891
Re: oil leaking
I've dealt with a couple of them. I'd change the oil for the customer,they would say it's to full,when it's right in the full mark. It would blow a bit if oil unless ya ran it with the oil level half way down between the full/add marks. These owners have had the boats for a long time,and learned to keep it a bit low. 2 seperate owners,never talked to each other. Both maintained perfectly,including changing all filters,breather filters ect every season. Must be the engine angle or something. These motors are clean,except the one I had to clean up the first time I had to clean it up. Both did it from new,they figured it out. Just a thought.
Grub
atwitsend
Re: oil leaking
Thank you everyone that i found to be true about the oil level in the engine . Also the older it gets the more the crankcase builds pressure .i am adding a newer stye rear valve cover with a breather element. Thank you all for your help, you are all the greatest !
