After I ran my motor on the stand today there was oil and water leaking out the centre of the prop after I shut it down.<br /><br />So...there is a seal that needs replaced....my question is what seal.<br /><br />I removed the prop and then the plate (#57) behind the prop with three small bolts that hold it in place and then I removed the 2 1/2" o-ring (#56), it looks ok but is that the seal that is failing or do I need to go deeper?<br /><br />It looks like I need a special tool to remove the bearing housing (#53). I also noticed that it is a reverse thread.<br /><br />Am I on the right track?
