basstender10.6
- Joined
- May 15, 2011
- 131
Last summer, my 1999 5hp evinrude 4 stroke was leaking oil from the midsection after being run for a while. I did a lot of research and I thought it was a bad head gasket. I just replaced the head gasket and put the motor back together properly. I went to start it up and it was running fine. But I had the hood off and noticed a little water dripping from the block into the engine "bay". After a 15 minutes it spit milky oil out of the breather hose for the valves. I shut it off and checked the dip stick which was milky. Then I drained the oil which was a complete milkshake. So, does anyone out there think that they can offer any advise to someone who is about to give up?
