Oil mix ratio on 80hp sea horse v4?
lbcboating
I'm little confused .. I just got an older 80hp sea horse outboard , it has 4 spark plugs does this mean v4 or 4 cycle or does that mean the same thing? It is likely a 66 or 67..
Also is there an oil/gas mix on these like the smaller 2 cycle motors that is applied in the fuel tank
Daviet
Re: Oil mix ratio on 80hp sea horse v4?
4 spark plugs means it has 4 cylinders, it is a 2 cycle and you must mix oil with the gas, 50:1 should be correct rario for the years you listed. If you would post a model number, we could tell you the exact year of the engine.
lbcboating
4 cylinders that complete 2 movements to make combustion ? Why would 4 cylinders not be 4 stroke ? That had me confused ....
Chris1956
Two cycle and four cycle motors are different types of engines. Four cycle motors like your car have permanent motor oil in the crankcase and valves to allow gasoline and air mix to be sucked into the cylinder, The valves close and the fuel ignited. So as the piston moves up and down, the four cycles are intake(piston moves down), compression (piston moves up), Ignition and power (piston moves down, and exhaust (piston moves up).
2 cycle motors allow gasoline and air mix, plus oil to move thru the crankcase and transfer to the top of the cylinder. Thus they have only 2 cycles. Power (piston moves down) and at the bottom of the down stroke, the fresh fuel mixture transfers to the top of the cylinder sweeping out the burnt gases, compression stroke compresses fuel mixture and oil in cylinder, while drawing in fresh fuel and oil into the crankcase. At the top of the stroke, the plug fires initiating the power stroke.
The number of cylinders is irrelevent to the type of motor.
That ought to confuse you, but it is correct.
achris
More fish than mountain goat
This might help...
attachment.php
kenmyfam
Good explanations already posted.
Don't forget to mix the fuel and 2 stroke oil. TCW-3 must written be on the 2 stroke oil container.
Good Luck and don't forget to read the "Top Secret Files" at the the top of page 1 of this section.
