I have had a problem with my 1999 Johnson 115 J115PLEEM for about 3 years now. Last fall it got worse. I have one cyl cutting out below 3000 RPM's (pretty sure it's the bottom port cyl). Last fall it would even cut out at 4000+ then kick in. I have a few things I know I want to check before taking it to a dealer. The oil I use is blue, I noticed my fuel filter (translucent) has a blue tint to it (oil mixing in the fuel filter). I am not sure if that is supposed to happen. The motor does smoke a lot. I have checked spark and compression 135psi on all 4 and that all looks good in the driveway. It never runs on 3 in the driveway or in the spring on it's first run. It gets worse as the season moves on. What would cause the oil in the fuel filter are, or is this normal. What would cause a cyl to not work below 3000 RPM. I guess we can start there. TIA Doug
