Oil mixtures
bmasters8
I recently purchased a 1975 Johnson SeaHorse, 115 hp, from a junkyard. I had some work done on it, but I cannot find anyone to tell me the correct fuel mixture. I've run it at 50:1, but my plugs are fouling out. Do I need to run it with less oil mixture, or is what I am doing appropriate for that older model? I would appreciate any information that I could receive.
JB
Re: Oil mixtures
50:1 is the correct mix, BMasters.<br /><br />What plugs are you using, and at what gap?
bmasters8
Re: Oil mixtures
Hello JB<br />I had a man put me a used lower unit on and I had him to tune up the motor at the same time, and he put in Champion QL77JC4, and they're gapped at 30. Is there a better plug that you would recommend, or perhaps a different gap setting?<br /><br />bmasters8
D
DJ
Guest
Re: Oil mixtures
Champion is the ONLY plug recommended for that engine. Other brands do not work well in OMC's, for some reason. The plug # is correct.<br /><br />If you idle alot, you can gap them at .040".<br /><br />Make sure the oil you use is TCW-3 rated.
