Oil on choke?
Ronniewhite
I installed a battery today and I wanted to make sure it was working. I pulled the choke 2 start it and it looks like oil on the choke. Is this a problem?
clemsonfor
Do you mean the choke butterfly? Oil won't hurt anything on the carburetor. If it looks like excess maybe look around for a reason?
Ronniewhite
No it's like on the metal rod when you pull the choke out. I thought it looked oily before I pulled it out and when I did I noticed like a golden looking oil on it.
Chris1956
Old 2 cycle engine? If so, oil kinds gets everywhere.
4 cycle engine? probably still not an issue.
This is on a 3 cylinder 25 HP 2 stroke.-----A wonderfully rugged and simple machine.
clemsonfor
Don't worry about it unless you see oil and gas leaking profusely somewhere. Oil keeps things from wearing out! Haha
oldboat1
Bet you have been cranking/choking without starting (old battery). Unburned 2-cycle.
Ronniewhite
I didn't have a battery until the other day. I was just pull starting. Always started between 1 and 3 pulls. I was able to get a 250dlr Napa battery that was only a year old for 40dlrs so that's why I installed a battery.
