Oil on transom.
glennkil
Hi I'm new to the boating world and own a aliminium runabout with 1972 Evinrude 25 engine. After reading this forum and taking my family to the coast for Christmas with an untried engine I thought it would make practical sense to change the water pump impeller. The job was relatively easy except I found a broken bolt between the main and extention housing (head held in by loctite) Grrr. Hit the water and engine ran beautifully but at end of session there was a noticable residue of oil (black) on transom below water level. There is also a degree of oily "sludge" coming out a small hole on the lower leg when the boat is left sit. Gearbox oil is clean with no water. There was half a tank of existing fuel in the tank which I topped up and added good oil at 50:1. The economy on this thing shocked me as well with an hours running using a good 9 litres of fuel (mainly at below planing speed) The engine has a rich / lean low speed control, maybe this isn't adjusted properly? <br /><br />What gives?? Have I somehow screwed up the impeller change or is there another explanation? Of course I don't know if the engine did this before the work because I didn't have it on the water (2 hours drive)<br /><br />Thanks in advance<br /><br />Glenn<br /><br />Canberra Australia
mikeyzx2
Re: Oil on transom.
Glenn, my Aussie friend, don't worry about the black oily stuff, that's just carbon and unburnt oil/fuel mix. You probably won't have to adjust the low speed needle unless the motor's having issues at idle speed. <br /><br />Welcome to iboats!
glennkil
Re: Oil on transom.
Wow!! You guys are fast.. Gotta love American service! Thanks for the help. I neglected to mention that a signifigant part of the leg below the exhaust / water reliefs (two holes) was also black but cleaned off with petrol. Maybe the existing tank of fuel was mixed with way too much oil? I'm going to try a total tank of fresh fuel next time.
mikeyzx2
Re: Oil on transom.
Not necessarily, Glenn. I can probably go out to my boat right now and there will be black coating on the skeg of gearcase. It's like soot from a chimney. It's actually good to see it coming out, cause that stuff over time will foul plugs, and cause the piston rings to stick. If you can find it, get a can of Seafoam, or Engine Tuner from boat dealers. Follow directions. There's also a good decarb topic in the FAQ's section.
