pcmpete
- Joined
- Apr 24, 2009
- 328
I have an external oil leak towards the front of my AQ130c put cannot pin point the source, I have cleaned the motor but there is no clear sign of where it is coming from. So I have decided to replace the following:
Timing Cover Gasket
Camshaft Felt Ring
Fuel Pump Gaskets
Valve Cover Gasket
Oil Trap Gasket
Oil Cap Gasket
Raw Water Pump O-ring
and the Oil Pan gasket.
My first question is can the oil pan gasket be replaced without removing the engine from the boat. There is approx 4" between the oil pan and the bottom of the boat, it this enough room?
and secondly, where else could an oil leak be coming from?
and lastly, is there any type of dye that can be added to the oil to help trace the oil leak?
Thanks for your time.
Timing Cover Gasket
Camshaft Felt Ring
Fuel Pump Gaskets
Valve Cover Gasket
Oil Trap Gasket
Oil Cap Gasket
