Re: Oil Pan Replacement
Tony, I just replaced the oil pan on my '88 4.3LX. I bought a chrome one from a speedshop for $39, only one I could get other than from Mercruiser ($179). It was 1/2" shallower than the OEM pan, which caused a bit of trouble for me, but I did get it to work.<br /><br />Check the condition of your timing cover when you do the pan. It may be rusty also. If you need to change it, clean the rust off the sealing surface on the harmonic balancer, if it needs it, or it will leak oil.<br /><br />The gasket for the pan ($45) was available at a local Auto Parts store, as was the timing cover and gasket set (another $45).
