Oil pressure switch, Temp Sender mounting
KV
I just put a new 4.3 Vortec lonblock in my boat. Upon removal of the old engine I forgot to record where the oil pressure switch(not sender) and temp sender mount to the block.The engine is a 92-95 range 4.3 Mercruiser/Chevy 45 BBl , electric fuel pump. Thanks
Re: Oil pressure switch, Temp Sender mounting
oil pressure switch should be just ahead of the oil filter....<br />water temp, up by the t-stat....
