Oil Pressure Switch
Quarterwave
Hi everyone,
I recently bought a new oil pressure switch, which I'm using as part of a switch from a mechanical fuel pump to an electric fuel pump.
Please see the pic for reference.
The gold-colored switch that is on the left is the new one and the black-colored one of the right is the old one.
As the new one looks totally different, is it still ok to use?
harringtondav
Both are your oil pressure gage switch, and assuming they put out the same resistance range, it should be OK, but has nothing to do with an electric fuel pump. The two terminal switch is your low oil cut out switch. It should be open at engine off, closed w/oil pressure, It needs to be wired in series with your elec. fuel pump. This will shut off the fuel pump at engine kill or stall, and kill the engine at zero oil pressure by shutting off fuel.
Bt Doctur
Both are your oil pressure gage SENDER, not switch . In the first pic the unit with the 3 blades is the fuel pressure switch. It has 3 connection 1 gets 12 volts from a switched source, 1 goes to the starters outer most post for power during cranking, the last goes to the pumps wiring
Bt Doctur
Quarterwave
Thanks everyone. I didn't have the wiring schematic from the factory service manual in front of me before I posted. Apologies!
Fun Times
The black one on the right is for your oil PSI gauge at the helm.....The new gold colored circled in red is normally used as a switch to sound the warning horn or change status of a red oil light......The chrome above the gold is for the fuel pump switch.
https://www.ebay.com/sch/i.html?_fr...acat=0&LH_TitleDesc=0&_osacat=0&_odkw=3857532
https://www.ebay.com/itm/OEM-Mercru...ender-Sensor-Switch-87-805605A1-/142233195668
OIL PRESSURE SWITCH
Brand: Indmar SKU: IND-645006
https://www.marinepartssource.com/o...MIrb696vmm3AIVxY-zCh0PyQI5EAQYAyABEgJu9PD_BwE
harringtondav
Semantics. Whatever. Where I was book learned, any device controlling electrical current, thus voltage, was called a switch. But I'll remember to go with the flow to avoid disagreement.
bruceb58
A sender is different than a switch. A sender has variable resistance caused by the oil pressure. It's just a variable resistor....not a switch.
bruceb58
