Oil Pressure Varience
Thomv
Should I be concerned that both of my motors are running different oil pressures while underway? My port motor is running 50 PSI while my starboard motor is running 42 PSI at 3,000 RPM. At idle both are about 38 PSI.
Alumarine
Re: Oil Pressure Varience
You could also swap the sender leads to the gauges to see if the readings are now reversed or not.
That would tell you if it's a gauge/sender isssue.
Thomv
Will give that a shot.
Thanks
Levithan
Banned
10psi per 1000rpm minimum is the general rule.
It could be senders or, one engine is a little looser than the other.
Those numbers sound fine though.
Robert D
Couldn't agree more. Even if the numbers are accurate, they are fine. A cheap way to check, get a mechanical oil pressure gauge and whatever adapter you need, to screw it in and verify the real pressure. Do it on both engines to double check, if the issue bothers you. I bought a glycerin filled pressure gauge, and have it mounted on my remote oil filter mount....just so I have 'real' oil pressure data. Something like this: New 3 1 2" Pressure Gauge 0 200 PSI 1 4" NPT Liquid Glycerin Filled | eBay or like this one that goes to 60 psi, which is what I have: Ashcroft 8923 Glycerine Filled Pressure Gauge 0 to 60PSI 1 4" NPT | eBay
Thomv
Last night I did have time to reverse both gauges. Over the weekend I will start both engines and see if the variance transfers into the opposite gauge.
gm280
With everyting stated above you could also have varients in the oil in each engine, even from the same manufacturer. Viscosity will change the older the oil is as well. But like also stated before the general rule of thumb is 10PSI per 1000RPMs is fine... Also check to see if one engine is running just a little cooler then the other. But I wouldn't worry the least bit if it were mine...
