Searched archive and couldn't find what I wanted. Any feedback is appreciated.<br /><br />2 things:<br />1- changed oil last night and noticed only 4 quarts came out. 4.3 holds 5, and I did not pump oil out, I used drain plug w/fitted drain hose from bilge. The oil pressure has always been in normal operating range. I did not check oil level last time I went out (I usually check it, but this motor has never used much if any at all), but I do watch pressure, and it has always been in acceptable range. Question-Was it ok if level a little low (I know not ideal), even though the oil pressure was there?<br /><br />2- This motor has always had oil specified by merc manual in it until mid-season oil change this year...I put HDDO rotella 15w-40 in, and I was a quart low last night. I have never had an oil consumption problem, and I only had 40 hrs on this oil change. I pulled a few plugs and they had a little black film from the oil, not too bad though. I am going with Penzoil HD-40wt now. Question- could the oil I used be the cause of the consumption, and can using recommended oil wt help reduce or eliminate it?
