Oil PSI gage
Redneckboat21
Hello i took my boat out for the first time this passed weekend and was checking things out and i notice that my PSI gage on the oil was passed 80 psi i was woundering if that is ok or what could be wrong
fuzzybob
Re: Oil PSI gage
I wouldn't fret too much. I had mine out the other day and pressure went to the 70's at first. Once things warmed up it dropped down to around 45 or 50. I'm running 25 40 wt oil and the water temp is up to 45- 46. Ice just left the lake two or three weeks ago. Just go easy till it warms up good.
havasuboatman
Ensign
Re: Oil PSI gage
What wt? Sorry what weight oil is what that meant. New oil, Cold water and high rev's 80's a bit high, but not to worry, your gauge is electric, I assume. Watch it, if it gets higher, test your gauge, or hook a mechanical gauge to the engine to verify actual O/P.
Schmoe
Re: Oil PSI gage
I've had my 3.0 reach about 85psi with a 20W-50 in it. Last time I did that.
Redneckboat21
Re: Oil PSI gage
the water is about 70 i say and i drove it for a good hour and it stayed at 80 psi and my boat takes 5w-30. so if the water is warmer the gage will be lower the water gage stayed about 240
Gary H NC
Re: Oil PSI gage
The water temp gauge stayed 240?? Yikes!:eek:....it should be more like 160...
What motor are we talking about here? Raw water or closed loop cooling?
you sure it calls for 5W-30..? Thats a new one too.....
Redneckboat21
Re: Oil PSI gage
it's a AQ131
Gary H NC
Re: Oil PSI gage
If the motor was really running that warm then the 5W oil would be thin as water and should have lower than normal oil pressure..
I hope its just a bad ground to the gauges and they are both incorrect.
Something is going on there...
Redneckboat21
Re: Oil PSI gage
yeah the water has always been like that since i got it last year but i cant remember about the oil so i am trying to figure it out
Rocky_Road
Re: Oil PSI gage
This has 'morphed' into two potential problems...!
I know that my engines won't continue for very long, at that temperature.
Got to be a dirty ground...somewhere behind the guages?
Gary H NC
Re: Oil PSI gage
I would start checking the main ground that feeds the dash and the connections on the back of the gauges.
You could run a temporary ground direct from the battery to test.
The temp gauge would be my first concern..hopefully the motor is not running at 240.
Don would know but i bet that motor calls for straight 30 weight oil too.
wca_tim
Re: Oil PSI gage
surely there's an electrical problem with the gauges... maybe the wrong set of wires hooked up to the wrong place or something? do you have any idea how hot the engine would really have to be to be generating 240 degree water temps?
Redneckboat21
Re: Oil PSI gage
I just looked at the boat and the water temp was about 180 to 200 and the oil was at 80 psi for sure
Redneckboat21
Re: Oil PSI gage
no i am not sure what the water timp should be that is what i am wondering
Redneckboat21
Re: Oil PSI gage
I took the boat out today and it was doign the same thing the water timp was about 180 to 200 and the oil psi was at 80 so i dont know
Gary H NC
Re: Oil PSI gage
Water temp should be around 160....
Did you try the ground from the battery to the dash? Or at least get a good ground to the temp gauge.
I would not keep running it until you figure out the problem..
Redneckboat21
Re: Oil PSI gage
yeah been a while no i have not done anything been too busy with a wedding coming up and still am i wanna take the boat back out but i not sure when that will be.
