Oil question
Cast-A-Way
I am changing the oil in my 4.3 omc this weekend and was wondering the only oil I seem to find in the sae 30 says diesel oil is that normal ?
Or what would the best oil be ?
Thank you
danond
Re: Oil question
Yes, you need to use straight 30 weight.
Cast-A-Way
Re: Oil question
Thank you danond
I did an oil change a couple of weekends ago with 10-30 and I find the pressure too high
So after the advice from the site I started looking for straight 30 weight oil and all I found said diesel but on the back of the jug said it could be used in gas and propane engines
Thank you I now know that it's ok to use
